OpenAero Meets Hawk Sky
Tritium
Amateur Extra Class K5TWM
Here are a couple of pics of my mounting method for the Hobby King V2 Multi-rotor Controller flashed with the OpenAero firmware ( OpenAero_1_11_A_PWM_STD.hex ) to stabilize my Hawk Sky in the windy conditions I always have at my house.
http://www.rcgroups.com/forums/showthread.php?t=1568554
With the Turnigy Receiver mounted to the "roof" of the nose and the controller board mounted to the underside of the canopy it makes for a very clean install.
Thurmond
Tritium
#3
Thanks, I pondered on it for several days. I LIKE clean looks. If you notice all the control surfaces are plugged into the reverse channels (2, 4, 6). Radio is reversed on all three as well. Now for a test flight. Wouldn't you know it. No wind for the first time in DAYS!
Thurmond
Tritium
#5
Channel 5 on the receiver is tied to the throttle input on the board for enable/disable of stabilization. I am using the "gear" switch on the Turnigy TGY 9X. Back is "disable", Forward is "enable".
Thurmond
colorex
Rotor Riot!
So in the end how did the stabilization work out? Is it worth the $15 for a KKboard? It's cheaper and lighter than 3 hk gyros :)
Tritium
#10
I think it works quite well as I was able to fly in 15mph winds without crashing but I am still tweaking it and a new version of the firmware that is better is due out very quickly*. Haven't been able to fly lately due to 35mph winds and 100 plus temps.
*Update: OpenAero V1.12 is now available so I will be re-flashing my board to it and we will see how well it works.
Thurmond
lobstermash
Propaganda machine
Yeah, that's pretty cool. I have a FMA Copilot system, which is the infra red one for $50-ish on HK. The KK board is much, much cheaper!
