OpenTX Pattern Sequence Caller
OpenTX Pattern Sequence Caller 1
Please log in to download
rockyboy
Skill Collector
rockyboy submitted a new resource:
OpenTX Pattern Sequence Caller - Let your radio talk you through an aerobatic pattern!
So how does an enterprising young pilot practice aerobatic pattern sequences when there is nobody around to remind them what comes next? Turn to the power of OpenTX! :D
With this set of OpenTX LUA and WAV files installed, every time the SH switch is pulled the radio calls out the next move in the pattern! :love:
How did this magic happen you ask? I started with a script I found on the net developed by Nigel Sheffield that did this type of function for an earlier version of OpenTX...
Read more about this resource...
myxiplx
I wrote something very similar in LUA for Jeti :)
Jeti flight sequence announcer
https://www.helifreak.com/showthread.php?t=839803
Current features:
  • On radio settings menu
  • Plays a list of audio files, configured in JSON files
  • Controlled by a single switch or button (single press for play, long press to move to next, double press to go to previous, very long press to reset to start)
  • User assignable control button or switch
  • Able to select different audio lists in each model.
  • Able to remember position in sequence, or restart each time a model loads
  • Switch timings may be customised if needed
  • Includes two sample lists
rockyboy
Skill Collector
Current features:
That's awesome - and now I've got all kinds of ideas for features to add to my FrSky LUA version :D
Very nicely done sir - thank you for sharing this!
