Wow, time for a much needed update!
The wings have been adjusted to fit well. What I ended up doing was cutting the spar alignments inside the center wing, which allows me to naturally line up the spars and just glue them in place (I HAVE NO IDEA WHAT GLUE WORKS WHEN BONDING WOOD TO PAPER ON FOAMBOARD!) when I get there. That being said, the plane will most likely have to be put into combat on Sunday as a ‘MERICAN send off!
Otherwise, I’ve gotten one fuselage completely done minus the electronics and battery hatch and, and the other is just about done as well. It just needs the formers installed. Next after that is electronics (which I already have wired and ready to install) and I need to finish the tail section (elevator and rudder, which will be built seperately and glued on once I’m there). All the posterboard turtle deck will be installed there as well.
Basically, I’m hoping to be able to get this thing in the air when I’m down there in less than 3 hours, box to airborne!
