painting brown foam board
FDS
You can use 320-400 grit Scotchbrite pads to key the surface, they are flexible and long lasting.
Another trick is to 400 grit sand the flat parts both sides before assembly, with a cork block. Use the auto grade papers, black wet n dry type. This has the added bonus of scuffing potential glue surfaces as well, aiding adhesion.
