Minwax on pink insulation foam?
Has anyone coated Owens-Corning Formular 250 with Minwax to hard-surface it,
and if so, did it harm it in any way?
http://www.homedepot.com/p/Owens-Co...x-8-ft-Tongue-and-Groove-Foam-24DD/100320335#
I fabricated a radial engine cowl and nose deck for a Yakovlev Air-5 (Yak Air-5) project I am working on
that uses many swappable build principles out of this foam, but after sanding and shaping it shows
how soft this foam is under the surfaces. I need to get a harder surface on it or it will get
hangar rash just looking at it to long, and I want to prime it for painting.
>>>> I noticed many people saying they use Windex to thin their acrylics.
At my LHS we use Windshield Wiper Fluid. It is basically the same thing, but only $2 a gallon.
I have not tried it with any paints I have used on my DTF builds yet,
but I do not expect it would act any different than Windex, just a bunch cheaper to use.
>>>> Someone asked about over-coating paints to protect the finish. I used Minwax on my FT SF
build and used Apple Barrel acrylics to paint it up, then I made custom decals with the Testers Decal kit.
http://shop.hobbylobby.com/products/custom-decal-system-995506/
I wanted a nice, smooth surface for the decals to adhere to, so I used clear semi-gloss
Krylon Fusion for Plastics in the areas for the decals, and it worked fantastic when applied
in light coats. For an even finish, and to protect the decals, I then applied it to the entire plane.
It does a fine job, and because Fusion dries so quickly, it minimizes the chance of damage
to the foam, once again, if applied in light coats.
