Painting for Dummies?
mayan
I also hang the plane for the celling outside. I use Super 77 to spray the template let it sit for a bit and than stick that to the plane and spray over that. When it's dry I'll remove it.
Tench745
I always mask off my motor if it's on the plane when I paint, but there's no harm in just painting right over the skewers, servos, control arms, pushrods, and everything.
I have not used it, but there's a material called "frisket paper." It's a low-tack vinyl type material, a lot like transfer tape, which can be used to make masks for spraying different patterns. Cut the frisket paper into whatever stencil you need and apply. It doesn't stick much so it should be safe for masking over other dry paint.
nickieffo
Frisket paper - that sounds great. Maybe I’ll try this for some basic template building and get back to everyone.
Is it better to mask off the motor and keep the power pod in or just remove the power pod if I can? It seems like i can remove it easily (as that’s how it’s designed, right?). I think I’d rather that than try to work around the electronics/motor/etc, even masked off.
FDS
Remove the power pod if possible. You can mask the motor if the pod is not removable, but you don’t want overspray on the rest of it. Be sure to fill all the holes in the fuselage, I use screwed up newspaper to do that.
nickieffo
Gotcha, will do. Should I be religious about filling up the holes? I’ll put paper in there etc but I’m okay with a little overspray in the fuse if it happens (unless there’s something I’m not thinking of).
Also - spray paint won’t melt the exposed foam, right?...
FDS
Can’t guarantee your paint won’t melt exposed foam. Paint the exposed edges with PVA glue if you are concerned it might melt, or test on scrap foam.
The stuffing in the holes just needs to stop paint going onto your servos, receiver etc inside, it doesn’t need to be super sealed.
kilroy07
That's just one more reason to go with a really light (Mist) coat first. Some "better" quality paints are plastic "compatible" that is they don't eat it as much as the cheaper stuff... but if you really put on a heavy coat right off the bat, you will see some deterioration.
Here is what I used on "Big Red" (my Legacy.)
nickieffo
Great. I'll both test on a scrap piece and certainly get a mist coat down first.
Big Red?? That's the name of our family's 195 in my profile pic! Would love to see a shot of your red Legacy.
FDS
It will be heavier than paint.
If you seal the foam edges with PVA and key the surface then spray paint should be no problem. I have painted foamboard with 2k auto paint out my spray gun, no melting. Example of 2k plane-
I likthe Army Painter cans for FB, they do tinted high build primers with great opacity.
mayan
Looks great!
@Fly-n-Low I use the rust-oleumum x2 and it doesn't eat up the exposed foam and I am not paitent to do mist coats. Just what I do.
FDS
Glad that worked out. Me and water based coatings have agreed to avoid each other!
I have looked at similar coatings here in the UK but nowhere local stocks them. I have tons of auto paint and the guy in the shop behind mine always has leftover colours in base which I can have for free.
