here's the first set of numbers, I'll do more to check for some type of consistency.
Pre Minwax weight, fully assembled, minus power pod and receiver: 110 Grams
After Minwax weight: 115 grams - disclaimer, I needed to re-glue the turtle deck. I don't know if the additional glue added any weight. I forgot to weight the plane before repair.
Weight after applying 2 coats of Apple Barrel paint (thinned with water): 125 grams
Weight after applying 1 light coat of Pledge: 125 grams.
Looking at the numbers it appears to be about 5 grams per coat. I find it interesting that the pledge didn't seem to add any weight to the plane. I also didn't pledge the bottom of the fuselage, I'm going to put packing tape on the bottom to add some strength. I'm not using any landing gear, the grass where I fly is typically taller and wheels don't roll in it.
I may also try some different brands of paint to see if they weigh more then others.
