Hionimi
Sky Pirate
Hi, it seems the law in my country (Netherlands) is about to enforce parachute systems on drones, I'm cool with that and would love to get something like that as not only does that qualify me to fly legally, but also prevents damage to anything and anyone which is great!
Now, there are a few things that trouble me about this system, first of all, it seems absolutely necessary to move sideways when deploying the chute to prevent hitting the chute on the way down when it is still below the multirotor.
Second, the system seems to only work when the multirotor is still hovering and not already falling. I imagine this could be a problem in case of an engine failure and the multirotor is already falling, especially if noticed too late.
Now, there's another issue but that mostly regards the model I fly. I have a DJI F450, which has rather short arms and large propellers. This manual shows that it needs to be put between two arms to make it work at its best. From there it can freely fall and perhaps even still be deployed successfully if the multirotor is already in free-fall. Now I guess you can see the issue coming, the plate to which the system is mounted is right underneath the propeller's blast of air, so it seems a good place to put it to make it work well, but a horrible place otherwise in the means of proper lift production...
I guess I could use the Flame Wheel's bottom plate as the mounting surface with a servo on top for the release mechanism and put the straps of the chute on the other side through the upper holes of the optional landing gear I have. But I wonder of the chance of ending up tangled in the chute wouldn't become a bit too high...
Thoughts?
Thoughts?
