Parallel charging can be tricky. It works OK if the batteries are run in parallel, which keeps them at the same voltage as each other, but if you use 4 different batteries for 4 different flights, they'll all be at different voltages. If you connect batteries, which are at different voltages to a parallel board, something's going to smoke. Be careful, it's not funny when a lipo catches fire!.
