bracesport
Hi Guys - Here are some shots of my Phantom V1 - the idea was to build it with low cost methods - my inspiration was the YODA with a poly wing and the BAMF which I fly - it is not a bad build, but ended up with an AUW 100g over my target (sadly the wing weight was the major culprit as I used 100g Carbon) - the wing had a quick connect system which can be seen in the attached forum thread below (also to be refined).
I have decided to build a V2 taking what I have learned to refine my process - the fuse uses 3D printed moulds without any surface cleanup (this time I will tickle them a bit more) - I am happy to share all the files for the fuse and the wing and even do a group build.
this is some of the history of the build - https://forum.flitetest.com/index.ph...33#post-660302
