Phat Hawk Build/Fly & Review (uberfly.ca)
Andre
Fly yes... land no.
Admin
While at Flite Fest back in July Chris from the After Hours Podcast tossed his 3DHS plane.
I immediately wanted one. What a great way to have fun specially in a small area (like your back yard).
Jason Uberig of http://uberfly.ca saw my post and sent me a copy of his Phat Hawk 3D EPP plane to build and review.
Last night I finally finished the plane and took it outside (in the dark) to have some fun.
Even with no expo or rates set and all the wires hanging loose the plane flew great.
Lifting out of my hands at under half power.
The kit as you can see is very simply, clean and comes with
all the bits to build the PH (I provided the motor, esc, prop, receiver and servos).
The instructions are super detailed.
Jason had suggested I use an air brush to paint the foam before assembly but
I opt'd for a foam brush and acrylic paint job due to the high humidity at the time.
The results are decent but I will go over the plane again
to clean up the colours as it did not really add any weight.
With all the parts removed it is time to cut the bevels into the wing surfaces.
Simple process thanks to the detailed instructions which provide step by step directions.
(I just didn't follow them that well.)
I used Foam Tak on this project and you don't need a lot to glue the control surfaces in.
Carbon rods and linkages.
Jason did caution me on cutting the carbon control rods and tubes. Carbon Fibre dust is nasty stuff.
Do it outside and wipe the surfaces down when you are done.
I used 3 HXT500 6.2g / 0.6kg / .08sec Micro Servo with some custom arms to maximize their throws.
(I'll get some detailed photos of them shortly.)
The 3D printed motor mount.
Jason provided the design and a local friend printed it out for me.
I ended up using the light weight design and drilling my own holes to mount the TURNIGY 2204-14T 19g Outrunner.
The assembled plane checks in at 150g without the battery.
Specs:
Motor: TURNIGY 2204-14T 19g Outrunner.
ESC: TowerPro 9g w12A Brushless Speed Controller (No longer stocked)
Servos: HXT500 6.2g / 0.6kg / .08sec Micro Servo
Prop: 8040 Propellers (orange - 5pc)
Receiver: OrangeRx R410X DSMX Compatible 4Ch/6CH PWM/CPPM 2.4Ghz Receiver
Battery: ZIPPY Compact 500mAh 2S 35C Lipo Pack
Stay tuned for a flight video of this amazingly fun 3D plane.
I still need to clean up all the wires, apply some more paint and setup recommended rates and expo.
Low D/R Expo
Aileron 60 20
Elevator 60 20
Rudder 60 10
Medium D/R Expo
Aileron 80 25
Elevator 80 25
Rudder 80 12
High D/R Expo
Aileron 100 30
Elevator 100 35
Rudder 100 15
AkimboGlueGuns
Biplane Guy
Nice build Andre. Is this one your first 3D plane (apart from the sukhoi)? It looks like a good first non stabilized 3D platform. They're good fun for indoor flying too.
During Flite Fest I'd ended up throwing up my 3DHS Slick right in front of the After Hours crew without knowing it, which was funny. landed turned around and Chris says nice flight.
Andre
Fly yes... land no.
Admin
Yeah you heard the podcast I would have flown all night with Chris' but we had to do the live podcast ;)
I wanted to buy one but the shipping on the twisted hobbies model was $60 USD.
Jason's plane has impressed me and I only flew it a few minutes last night in the dark.
Can't wait to dial it in.
