Piglet FT EZ Power Add-on TX question
bschatz
Hello all, so I built my FT EZ Piglet yesterday and I have been able to bind it to my FrSky X20 TX with an iRangerX iRX4 lite module. The question I have is in Josh's build video he mentions on the FT TX to use "high" range, on a non-FT TX is "high" 100% throw, or is it 125/150% throw?
Thanks for your time, and I'm so looking forward to flying my Piglet this weekend.
- Bill -
FoamyDM
Building Fool-Flying Noob
Hi Bill,
The FT TX has a 2-pos switch for diff rates. There are two rates for the EZ-pack and it refers to the amount of differential thrust to facilitate turns. As the motors are the only thing the board is changing. low is like a 20% difference, and full is like 50%.
I use my T16 with multi-protocol which link directly to the control board, so I can use my man-size transmitter. the rate is just a channel input controlling the level of differential for a turn.
Does that help.
bschatz
Hi Bill,
Does that help.
Hi FoamyDM,
Thank you for the explaination. I am seeing one issue with the differential though. I have no differential programmed into my TX. And my TX has the channel sequence set to: AETRA2 (default no mixes). I noticed the right differential thrust seems to be built into the EZ-pack system as there is a major thrust change when I move the aileron stick full right(there seems to be not change to the thrust until I am almost at full right stick). The left differential doesn't seem anywhere near as pronounced, unless I chop the throttle and hold the left aileron, then the left differential kicks in.
Do you have any differential programmed into your TX, or any other special programming?
Thanx for your time.
- Bill -
Dan-O
I have to admit using the little transmitter that comes with the FT EZ Pack kit is actually pretty good, all things considered. Yes, it's all preset and you can't change any settings. Yes, it can feel a little toy-ish. But... I have made several diff thrust planes and, well, for what it is, it ain't bad. I was planning on using my TX16 with the EZ Packs, but for simple foamie (or some of the Rogallos that I've built) it's very convenient to just use the FT radio. The batteries last a pretty long time too and the range is fine for the little stuff.
Latest vid and build using the FT transmitter and EZ Pack:
bschatz
Yea, I guess I'll just get the FT TX. I was hoping not to get another TX as I already have 6 and I'm tring to move my models down to just 2 TXs, on well. Thanks for your reply.
The Ravens Forge
Hi Bill, before you buy another transmitter, a couple of things might fix it on the X20. None of them need a mix in the TX.
Throttle headroom. Differential works by speeding one motor up and slowing the other. If you're near full throttle, the motor that should speed up is already maxed, so all you get is the other one slowing down. That's why the turn suddenly "kicks in" when you chop throttle. Try your stick test at about half throttle and see if left and right even out.
ESC calibration. If the two ESCs weren't calibrated to the same throttle range, one reaches full power earlier than the other. That makes the differential lopsided, and it gets worse as throttle goes up. Re-running throttle calibration on both ESCs (props off) is worth doing.
Aileron range at the board. Open the channel monitor on the X20 and check that aileron sits dead center with trims zeroed, and that full left and full right reach the same distance from center. Any subtrim or uneven travel shows up as a weaker turn in one direction. The multi-protocol module can also change the output range a bit, so check what's actually being sent, not just the percentages.
If it still feels "dead" until almost full stick after that, check the channel monitor for whether full stick is really reaching the end of the range.
