Pizza Trays Plane... aka the Very Easy Plane V.E.P. built with cheap F939 parts
RC Lover
Hi everyone,
after building 9 prototypes of the X-37ABC, without being able to design a fuselage that generates enough lift (due to low airspeed), I've decided to use the last prototype I made, as a base for the shape of a proper new RC airplane... with wings... this time! This is the Very Easy Plane (V.E.P.) and I've "flite-tested" it a couple of times, with very good results.
http://www.instructables.com/id/RC-VEP-Very-Easy-Plane-Built-Using-Polystyrene-Piz/
V.E.P. has been designed, built and flown, by me and assembled with £15 F939 parts...
http://www.banggood.com/WLtoys-F929...ller-022-p-947009.html?p=ZL2104540902201404G2
http://www.banggood.com/WLtoys-F929...are-Part-p-930768.html?p=ZL2104540902201404G2
http://www.banggood.com/WLtoys-F929...are-Part-p-930767.html?p=ZL2104540902201404G2
This nosecone will make the life of the propeller longer...
http://www.banggood.com/WLtoys-F929...or-Cover-p-930773.html?p=ZL2104540902201404G2
A female Losi connector to swap the JST 2.0mm PH JST of the standard PCB
http://www.banggood.com/DIY-1_25mm-...dcopter-p-1080391.html?p=ZL2104540902201404G2
I own already a "multi-functional" FlySky FS-T6 Transmitter
http://www.banggood.com/Flysky-FS-T...X1-Mode-2-p-73199.html?p=ZL2104540902201404G2
You need also some UHU Por (foam friendly)
3 polystyrene Pizza trays (the less difficult part of this project was to eat pizza)
2 bamboo skewer for barbecue
2 popsicle stick
a piece of velcro for the battery
2x 1mm pushing rods
2x horns (I used servo arms shaped for this purpose)
Xspense
This is ingenious! Obviously, it's not the prettiest plane ever made, but it is one of the more creative ones. For what its made out of, and for how cheap it is, this is perfect for those wanting a first build that can be messy, cheap, and actually flyable. Well done sir. Well done.
Safe Flying,
Sam
RC Lover
Safe Flying,
Sam
Thanks for your comment!
The Very Easy Plane has been designed by trial and error :)
which is (in my humble opinion), the best way of doing it.
Tg
