Hello everyone,
After finally finishing my FT Explorer, I went out to try to fly it yesterday. I wanted to just practice taking off and landing so that I could get the basics down and not quickly destroy my plane. However, the opposite happened. Before I flew it, I made sure to make all necessary pre-flight checks (CG, Range Check, etc.). However, when we first tried to launch the plane, it flew straight into the ground. I had 50% throttle and barely any elevator if I recall, so I thought that maybe I just needed more throttle and elevator. I tried again with those adjustments, but it still wouldn't fly.
On the second or third try, a section of the boom nearly split. Basically, what happened was that the top part stayed fine while the bottom and the sides basically got cut so that the boom could move. It wasn't too surprising because there had been a big fold/ crease there because of something that had happened during construction. I tested the CG again and changed it a little though it may have been only seemed off because of the wind pushing at it. Determined to get it to at least get off the ground, I kept trying.
I believe at one point the rudder veered to the right after another fall. I didn't notice this and tried to fly it again. After that try, the part that got cut got completely cut off so that ended that day's adventure. (The rudder may become like that after this fall).
Sad and dejected, we left. I tried to do some research, and I concluded that this may have been the fault of the motor or the raised elevator. However, I do not believe it was the elevator's fault because I don't recall it being raised the first time.
Here are some of the specs for my plane:
For my servos and motor, I used the Flite Test C Pack.
I also put a carbon fiber rod in the wing to reinforce it.
I honestly am really confused on why it didn't fly, and I would really appreciate if someone knew how I could fix this. Thanks, everyone.
