Planes with 2 part wings
Nitroracer
Do think you will make a training plane with 2 part wings I want to make the simple storch but the wings are too big for the boot of my car I can just fit the body in going by the measurements the club only allows planes with large wingspan and weight of at least 1kg
leaded50
easiest is using CF tubes to make connection between the two wingparts, its then stiff enough to ensure connection is good without breaking easy. Two tubes who goes into each other as wing spars
Bricks
I have used yard sticks for wing spars cheaper and actually pretty darn strong and you can have dihedral using them.
If you're using carbon fiber rods/tubes you'll need a semi rigid joiner. Thick wall tubing bent to shape is what I use, however, what part do you think fails?
