Can any one help with converting a JPEG picture into a PDF that can be printed out to build?
CrashRecovery I'm a care bear...Really? Mentor May 30, 2013 #1 Can any one help with converting a JPEG picture into a PDF that can be printed out to build?
Craftydan Hostage Taker of Quads Staff member Moderator Mentor May 30, 2013 #2 DAFBFD58 said: Can any one help with converting a JPEG picture into a PDF that can be printed out to build? Click to expand... Simplest way for the "format" -> PDF is a PDF printer driver. I've had good success with CutePDF, but there are many others. Good luck with the layout. look forward to seeing the build!
T twistedsteelpony Junior Member Mar 1, 2014 #3 How do you want to build it? Simple prop in slot profiles Or fully shaped fuselage with twin deducted fans Are you building out of foam? Or balsa or what? I would like to help but more info is necessary
xuzme720 Dedicated foam bender Mentor Mar 1, 2014 #4 twistedsteelpony said: ...twin deducted fans... Click to expand... Are you a licensed tax broker? And is it legal to deduct fans twice?
