jimmyjames
i have two naze32 rev 6 boards, one new never flown and one that has been used before. they are both having the same problem. when you hook them up USB only everything seems fine, you can flash firmware and change pid save and reboot no problems. however when you want to calibrate the esc as soon as you hook the lipo up cleanflight freezes, this is extremely frustrating because i cant arm the boards or anything they just sit there flashing.
does anyone know what is going on.
ive tried different computers, USB cables, Cleanflight, Betaflight, Baseflight. nothing works and i can not fly.
- boards hooked to computer with USB only eveything is fine
- soon as lipo is plugged in clean flight freezes and if you switch between tabs you get waiting on data.
- if you connect lipo first and then connect USB it will not connect to clean flight.
