pls check out my new video with my bolt 250
alex jr
pls like and sub
video
https://www.youtube.com/watch?v=IzUsfs1EbZM
quad specs
trying out the new blackout motors from bolltrc
2206-2350kv
pilot alex genovese jr
cam man Zarak Khan
supplier bolt rc
http://boltrc.com/
quad
bolt 250
esc-little bee 20amp
motors-blackout
fc-naze32
props-hq5x4.5
specs and info
Blackout motors are manufactured to order by T-Motors . Tiger Motors, when only the best will do, the gold standard for mini quads. The 2206 KV2350 with 4S is just one over the top power monster.
These are also the same as the Luminier version FXC2206-11 2350kv.
Specifications
KV: 2350
Configuration: 12N14P
Stator Diameter: 22mm
Stator Length: 6m
Shaft Diameter: 3mm
Motor Dimension Diameter x Length: 27×18.5mm
Weight g: 30g without prop adapter
ldle current10@10v A: 0.3
No.of CellsLipo: 2-3S
Max Continuous current amp 180S: 18A tested on 7" prop 8A on a 5x3" prop
Max Continuous Power Watts 180S: 180W
Max. efficiency current: 2-5A 80%
Internal resistance: 82mQ
cranialrectosis
Nice flying!
Just in case you don't know and if any newbies are watching, the warble you hear when you 'punch it' is caused by a need to tune PIDs. :)
Welcome to FliteTest. That sure is a screamer of a quad.
Snarls
Gravity Tester
Wow thats some extreme LOS skill. I would be scared of making circles that fast in front of me. Cameraman is good too.
