Plywood cutting hardware?
f237khan
Hey fellow pilots!
Been on a roll with scratch building FT planes. But when it comes to plywood pieces, I get stuck in the build process.
Can you suggest any good plywood cutters? Smth that is home friendly.... thinking a mini machine sorta thing.
Thank you and happy building/flying :)
Fuad.
Foamforce
If you’re also looking for an entirely new hobby to use the remainder of your free time, you can get a 3d printer. Most of the plywood parts have available plans for 3d printers, and those parts are generally as good or better. The exception is some longer plywood spars used in Master Series models.
3d printers are surprisingly cheap. I got mine on sale for $100 a couple years ago. But it’s only cheap if you don’t consider the value of your time. 😂
Masterguns
Many tools & affordable options for this hobby, at least.
*This cheap but considerably good quality saw from Saker. They make many types of electric powered mini table saws, lathes, drill press. It's been a real nice set up for small hobby type stuff that we'd be cutting or sanding, etc.
*3D printers are pretty cheap these days depending what the user intends the end product to be. There are zillions of free designs that folks have made available on Thingiverse, Cults3d & other sites to upgrade these planes & especially 3D plastic parts to replace using wood & items that can beef up metal parts. The digitally modded or purpose made things you can make with a 3D printer that don't even need to be cut are pretty much endless.
*Higher end Dremel like a 4000 series that have quasi vice attachments among other feature that allow you to slide over wood as a router & other material to make straighter cuts without having to rely on our varying degrees of steady hands.
*Those wooden handle (preferred) hobby hand saws that allow you to change the depth of the blade & a metal miter box. Various sizes like the stuff you can get in the model section at Hobby Lobby or Amazon or Harbor Freight.
*Most 5-10-20w laser cutters are cheap today, as well, & can work wonders to mod or make replacement parts, but, again, if you're not taking an open free source design from an applicable site, you need to use a vector program to trace a rasterized PDF or similar file with the item you need & convert into a DFX file for the cutter to be able to read said file to be cut or etched.
Take a couple days & do some www surfing. You'll find whatever it is that fits your particular needs. I have all of the above & I've been really happy with what you can cut or design with these machines. Peace to you & yours.
Best regards,
Masterguns
