neistridlar
Judging by several of the flitetest videos, it seems that dropping bombs from model airplanes is not nearly as easy as it sounds. The biggest problem seemingly being that just letting go of the bomb isn't always enough. And a second issue being that servos don't do so well under continuous load. So I decided to try to come up with a simple mechanism that would both hold onto the bomb without load on the servo, as well as pushing the bomb out once released. This is what I came up with:
It uses two pieces of moderately thin material, say 4mm plywood or similar, as well as two pins, could be barbecue skewers. The mechanism resides in a slot in the wing. The pins are attached to the wing to provide a secure stop. There is a c-shaped piece which is attached to a servo, or mounted on a pivot, and actuated remotely by servo wire. The inside of the hook-shape is circular and concentric with the pivot, so that when the bomb is grabbed, no torque is put on the servo, and only a small torqe is required to release it. This is similar to the trigger mechanism on a gun, where only a light pull of the trigger can release a heavy spring. Once the hook is released the pusher engages, and the torqe from the servo is used to push the bomb completely clear of the slot. As long as the servo has enough torqe to push the bomb out, it should be nearly impossible for it to not separate from the aircraft.
It seems odd to me that I couldn't find other examples of similar mechanisms, given how simple it is. Maybe it is because it's a bad Idea? Anyways I intended to build a prototype in the not to distant future. Hope some of you will find a use for it as well.
