FDS
1c so capacity (mah) divided by 1000 is a good rate for a dodgy pack. In the case of your 850, set the charge current to 0.85A. You should balance charge it at that current ideally.
The solution to this is either- run two 6x4 two bladed props or buy a bigger battery. The 2200mah you have may be a little heavy, the mini guinea has lots of thrust but they can be weighty. I like the Tattu ones, a midsized one like a 1300-1500 mah would be good, the Tattu Graphenes are designed for race quads and have super low internal resistance and great power outputs.
