Would a E Flite power 46 be a good match for the MS Corsair? Thanks Dan
Dantheglassman New member Apr 9, 2020 #1 Would a E Flite power 46 be a good match for the MS Corsair? Thanks Dan
leaded50 Legendary member Apr 10, 2020 #2 Ideal for 40- to 46-size airplanes weighing 4 to 7 pounds (1.8–3.2 kg) Ideal for 25- to 40-size 3D airplanes up to 5 lb (2.2 kg) It seems should be a pretty good powerhouse, for even close to twice the weight. 1:1 or more power to weight ratios is unrealistic as scale flying.
Dantheglassman New member Apr 10, 2020 #3 In simple terms is that a yes, or no? Would one of the monster planes be a better fit? Maybe the monster spitfire. Thanks Dan
leaded50 Legendary member Apr 10, 2020 #4 a Master Series style plane would never reach the weight of 1.8 - 3.2kg by normal build, far lower... so yes, its a yes, it will even be perhaps "overpowering", a fast one!
Dantheglassman New member Apr 10, 2020 #5 Thank You Sir I sometimes need to be hit over the head. Just ask my wife Dan
leaded50 Legendary member Apr 10, 2020 #6 its gonna be big though.... 50 x 50mm.. thats even more than the FT powerpod, so you probarly need adjust the pod/formers, or make another motormount.
