FL-Hawkeye
I'm working on my first Flight Test build, a simple cub. The build is going well except I had a problem with the ESC while testing motor rotation.
I'm using the same servo tester Josh used in his build video. I'm pretty certain I hooked it up exactly like he did [turns out not true, see posts below]. Below is a picture of how I had it hooked up (the battery/ESC cable is not connected in the photo, but was connected when the wire melted).
When I connected the battery to the ESC, the one of the ESC wires that goes to the receiver (in this case the servo tester) melted.
What could have caused this? If somehow I connected the ESC receiver wires to the server tester backward (putting the signal wire on negative) could that have been the problem?
The ESC still beeps when I connect power to it.
The servo tester works fine, I tested with a servo before and after the incident.
Thoughts on what caused the smoked wire? Since the ESC still beeps with power connected, maybe it will still work after I replace the smoked wire?
Thanks in advance for your replies.
Mark
Mark
