power pack F hex key for motor screws
TBA7058
Hi all, we have got the might mini arrow. We're building the power pack, and can't screw the motor screws into the motor as I think we need an Allen key/hex key, is that right? it doesnt seem to come with the kit
If you are using the cone shaped one, a control rod wire through the hole will do. If using the hex nut, a pair of pliers shall work well.
Edit: I realized what you meant, yes you need a hex wrench, unless you have other properly sized screws laying around.
alan0043
Hi TBA,
You will need an Allen key/hex key. The motor does not come with an Allen wrench. I forget the size you need. Good luck on your build.
alan0043
Thank you, I’ll order some, I’ll measure the hole as best I can first and get a little set
Hi TBA7058,
I found a F pack motor in my parts box measured the screw. The screw is metric. Size is 1.5 mm wench. I like the the longer arms. It's always nice to have a standard set and a metric set of Allen wenches.
TBA7058
Hi TBA7058,
Thank you so much for checking for me! So grateful! I’ll order some now!
