I bought a few of them. the 2200's seemed ok but on the 1000kv the set screw holding bell to the shaft stripped out. I had to retap it and use a larger set screw. Also, the shaft is just a bit longer than the prop collet so you have to cut it or run a spacer. if not and you nose dive it will push the shaft back into the motor and again strip the set screw.
