Hey guys, this is my first post here so if this is in the wrong section feel free to move it.
I've recently built the FT Delta as my first plane to learn on and being new to RC planes I ended up making it a bit heavy by covering the surfaces with packing tape to waterproof it and add strength. As a result I have to run at full throttle to get it to fly well which makes it decently fast for a learner plane.
As your expect for a learner Ive ploughed nose first into the ground many times at full throttle and it pretty much turned the nose into a crumpled mess, still flyable, but not great.
I made a new power pod for it with a small change to try and avoid this. I hot glued 2 paddle pop sticks to the inside floor of the power pod, pressing up against the firewall to help stop it from crumpling back and it's helped a lot! Nose dived after a loop and it came away with no damage.
Figured I'd share this small mod in the hope that it helps someone else with the same problem.
