I'm still relatively new to RC, After flying the heck out of my FT Tiny Trainer I decided to built a FT Storch using Power Pack C, running a 9x4.5 prop, and a 3s 2200mah 30c Lipo. It wasn't every time but enough flights would end with a loss of power and the motor intermittently cutting out to be concerned. The lipo voltage wasn't low when this happened. Most of the times when I had issues were when I was fighting windy conditions. The ESC would be hot when I landed so I moved the ESC to try and get it more in the airflow from the NACA duct. I didn't fly it much after that (not my cup of tea and frustrated with the power issue) so it's hard to say if better cooling helped. Recently I got a FT Racer speedbuild kit to use the power pod since I wasn't flying the storch. Maybe I'm naive, but one of the thoughts was the racer would likely have less drag and less taxing on the motor/ESC, not to mention 2 less servos (flaps on the storch). Well, the first two flights of the racer tonight (same prop and lipos) had the same issue. Now I'm realizing there is no air flow through the power pod on the racer like there was on the storch. Still a cooling problem? I'm not running anything beyond the recommended setup except a frsky telemetry voltage meter tapping into the battery leads? Have other people had this issue? Do I have a bad ESC? Motor? Is the C rating too low on the lipo for this setup, if so wouldn't the lipo be hot? Or am I overlooking some other obvious/fundamental issue?
