So many times I see people do the standard "Stick Waggle" prior to taking a plane out to the flight line and they look to see that everything is moving! This only proves that the plane is connected to the TX, not that the plane will go the way the pilot wants!!
Well, this is not a true test. In the bad old days of 35Mhz (not sure what you guys over the pond used) it was possible to fly the one plane with the transmitter set up for a different plane, various settings can be reversed and this would lead to disaster.
In the days of 2.4Ghz it's not so much of a problem, but I have always thought that a proper surfaces check is always a good thing to do before a flight.
Here is what I was told to do.
1. Standing Behind the plane with it facing away from you, say to yourself the mantra "Right Up"
2. Hold both control sticks (assuming mode 2) all the way down (towards you), and all the way right at the same time.
3. Now say the mantra "Right Up" again and look at the plane The RIGHT AILERON should be UP, The RUDDER should be RIGHT and the ELEVATOR should be UP, see what I said about Right Up?
Once that's done you know the surfaces are going in the right direction, you can then do your waggle of the surfaces to check the throws are the same in the opposite direction (this checks for binding of hinges etc)
This may sound like nonsense, but it works for me, and I teach it to all my new RC students.
