presenting the Nitro baron
Bricks
Nice job that coroplast can be some strong stuff and cheap. Have a local sign shop I can get there pieces and left overs for free. Looks like you are flying that on 72KH with the long antenna.
#7
yes i still fly with 72Mhz, i have a pacemaker and any 2.4Ghz radio makes it do strange things like recording false heart troubles. my doctor and i have decided when holding a radio the body becomes part of the antennas groundplane and that causes the issue. i can have friends stand right next to me using a spektrum radio with no issues but the moment i take the radio in hand it goes wonky.
#9
maiden went well, no major surprises, just minor tweaks, the throws on the ailerons are awesome but the elevator leaves it wanting more. easy enough to fix but i will look into that after i add another ounce to the nose she felt slightly tail heavy. did make one major change before flight, the rudder had a nasty warp grow in it so i made a new one an swapped it out.
i also tossed on some more color with wine wing an tail markings and i am very glad i did, it can roll like a drill bit.
#20
Do you, by any chance, have pictures of the motor mounting details ?? wood reinforcements? wood spar?
Thanks a lot for sharing!
no pics but i can tell you it is a half inch ply firewall held in place by screws through the coro and the spar is a piece of 1/2X1/2 popular.
edit, i found one pic from the big baron build. i scaled it even bigger to a wingspan of 48 inches. you can see the screws holding the firewall and rear bulkhead in.
