Bertrand Mourey
Hello guys,
I am trying to build up the electrohub quadcopter from flitetest using electronic kit from ready to fly quads but I have some problems powering up the flip1.5.
Basically, I am at the point where all my ESCs are connected to the distribution board. I plugged the 4 of them into the flight controller. My receiver is bind up correctly and connected to the flip 1.5. However when I power up everything, I hear the motor beeping, the receiver is showing red steady light but the flight controller won't power up ...
I also have tried to connect the flight controller via usb and use the mutliwii configuration software. The flip 1.5 will power up correctly and I am able to calibrate the radio switch using the software. That means that the receiver input are well read by the flip1.5.
Do you know why the flip won't power up when powering up using the battery ?
Do you think something is damaged or else?
Thanks a lot in advance for your help, I am just so close to make it work ... !
Regards,
Bertrand
Regards,
Bertrand
