tyoho
This has happened a couple of times now and it's staring to tick me off.
My Spectrum DX6i seems to be re-programming itself.
It randomly turns mixes on and off and sometimes inverts the mix values.
Today it turned on a aileron-elevator mix on both mix 1 and 2, in my Spitfire program with annoying results.
The spitfire program worked fine yesterday and I didn't make any program adjustments.
I have four models programmed and two of them use both mixes to do elevons, and those mixes are not switch activated.
Since this has happened to me a couple of times, I always check the control directions before I launch.
I guess I could have not noticed that the ailerons were moving when I moved the elevator this last time.
I haven't had it glitch while I was flying, and hope that it is only happening when I switch models.
Has any one experienced this problem before?
