drpoulette
Hi everyone...I bit the bullet and decided to try to build my first multi rotor...a versacopter 280 that just came out. I'm brand new to all of this.
I've done everything by watching the videos and putting it all together.
I'm to the point to configure Cleanflight on my Naze32 board. I get it all set up, flashed the firmware to the latest stable build. So far, so good. I'm using a Turnigy i6 transmitter with the ia6 receiver.
However, now when I try to check my receiver/transmitter, I get a problem.
The problem is that when I test the receiver in cleanflight, the pitch and roll move together. I move the right stick forward, and the pitch and roll both go to the right. Then, when I try to pull the right stick back, there isn't that much movement, but if I pull back and to the left, the values for both pitch and roll go down (to the left in cleanflight).
I've tried reflashing the board, checking all of the wired connections, making sure there are no mixes on, and everything else I can think of.
What do you think I should do next? I'd love to get this thing in the air soon!!!!!!!
