mattiethijs
Hey Guys,
I recently received my tiny6x with a FlySky FS-i6 to get into fpv flying. I tried to bind them without succes. Then I went to betaflight to try and connect the tiny6 to my pc and there I was also unsuccesfull. Previously I have only flown crappy rtf drones with the controller included. I thought I would be able to figure out this next step but it turns out I dont. Any help would be great. Below are the steps/results I took.
When I plugin the tiny6 to usb (boot button pressed while connecting to power, released after power is on), windows does make the sound to show it recognises a new usb connection.
When I push connect on betaflight it says:
2019-01-14 @ 16:00:29 -- Serial port successfully opened with ID: 7 (it starts with 1 but this was my seventh attempt)
2019-01-14 @ 16:00:39 -- No configuration received within 10 seconds, communication failed
2019-01-14 @ 16:00:39 -- Serial port successfully closed
I figured maybe I needed to setup the configuration so I went to the firmware flasher. After I put the settings to:
show unstable releases: off
Spracingf3
lastest version
no reboot sequense: on
flash on connect: off
full chip erase: on
manual baud rate: 256000
after pushing load firmware and then pushing flash firmware it tells me:
2019-01-14 @ 16:06:07 -- Failed to open serial port
Can anyone help me to the next step? Much appreciated.
[edit] rx2a-pro receiver [/edit]
Spracingf3
lastest version
full chip erase: on
