Normally when you bind the screen will say something like binding and then bind ok if bound - pre binding the Rx light will blink fast - when bound it will slow blink - after that I would normally pull the bind key out and the light will now be steady - power down Rx and Tx - re power with servo connected should be the next step?
Still have problems - If you don’t have the manual get it online - In the Tx go to the settings menu and explore options - you should be looking for output options and PWM for that Rx.
if the Tx and Rx came together they should work and the Rx would normally be pre bound.
I'm going to post steal a little bit here, but I don't think this is worthy of it's own post, and it's kinda related to prendon66's question. I'm attaching a picture of the 2 transmitters that are coming in the mail with the fs-i6 I got on eBay. Obviously the one labeled to match the transmitter should work, but the other one is different. Maybe an old one the seller didn't need and threw into this auction to make it sell better. Anybody recognize that one, and am I going to have similar issues with binding? It's still in the mail, so I can't verify anything yet, I'm just getting my ducks in a row before they hatch
**Edit** I may have already found my answer after some quick research on eBay's related items. Looks like that other one may be a fs-r6b receiver, using the slightly older AFHDS PPM protocol, which based on what everybody said to prendon66, I should just need to make the changes in the Tx you told him to try if I want to use that receiver. Cool cool. So another question, and one that might help prendon if he gets that one working and gets a second receiver as well, the fs-i6 can store multiple models. Does this include saving the protocol types in each model, or does that just save trim and what not, but you have to change protocols (sorry if that's the wrong term, I'm thinking of this in IT terms) every time manually?
