buzzbomb
I know nothing!
I was so excited. I built the plane. With help, I got the A Pack to power it. I learned to program a transmitter and again with help (thanks, Hai-Lee) I got all the electronics working. Then it went down hill into a hole at the bottom of a crater where it crashed and died.
Linkage stoppers. They don't work. The diameter of the screw was so much larger than the holes in the servo arm, that I hand drilled the hole with a dremel bit to widen it out. The plastic still split. I thought, OK. The nut will hold it in place. Only the nut can't because the servo stoppers are only threaded to 50%. The nut can't meet the broken plastic.
I've already broken a control horn trying to do a Z-Bend. I am essentially grounded. My plane that has never flown, cannot fly. I've got an email into the FT Customer Service department. We'll see what they come up with.
