jaskoller
Ok, I'm back again. I appreciate all the help I've gotten so far.
I've searched this forum and web and have found no real definitive answers. On my Tricopter (David W's tricopter design) I'm using the following:
ESC's: (HK 20amp)
ESC http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=40684
And I have theHK Programming card)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=35668
I have had several successful flights on my tricopter so far now. However, I have had a couple hard landings due to the ESC losing power after my battery senses what I'm assuming to be the low voltage limit. Now, I don't want to run my batteries to low, but I don't want my ESC's deciding when that is. My question is, if I program my ESC as NIMH will they stop shutting down? (if that is even what is going on) I currently have the card set to "BATT protect 2.8V/50%" but after it shuts down I check my battery and I have 3.6Vmin (resting). And In a hover I wouldn't think that I'm pulling that battery down to 2.8v.
I'm using DT750's
I'm not sure of my AUW, I'll have to get that.
I'm using some 3s 2200 20c
I'm used to flying planes and "purchased" quads (X4 and some other small quads). This homemade tri is new to me so bear with me!
Any Ideas?
ESC's: (HK 20amp)
I'm using DT750's
Any Ideas?
