octodreamerFNG
so here's what i've got so far...
Frame: Flitetest “Knuckles” H-Quad
(then i picked up a combo pack from lazer toyz)
Motors: Emax grand turbo 2213/935kv
ESC’s: Emax Simon series 20 amp
Props: 8x4.5 Emax
Battery: 3300mah 11.1v 35c
(then i went a bit overboard but the goal was to buy big to upgrade later into a hex or octo... so i wanted the good stuff)
FC: Pixhawk +GPS
Radio: Taranis X9D Plus + X8R-PCB 8/16 telemetry receiver
progress so far has been spotty, we laid out the knuckles, drilled it with a smaller bit than we should have and had to screw each bolt into place... this caused a few of the bolt heads to strip and they are now stuck so i haven't finished the frame yet and need to buy some new ones. probably going to break it all back down and re-drill all the holes with a bigger bit.
i managed to solder the bullet connectors for the ESC's with spotty sucess, had a lot of solder coming out the holes in the isdes and it made for an interesting (frustrating) job to heat shrink them... but i powered through it.
i completely botched the solder job on the power distribution board, luckily i started with soldering the wires onto the dean connector, i was right in the middle of soldering the second wire when it dawned on me that i was soldering the wrong side
. it wasn't fixable, it's now in the trash and i've still got the unmolested board.
this turned out to be a good mistake though, because the more i look into the build the more i want to switch to xt60 connectors. not only because it's what the pixhawk power supply cable has, but because it seems like a much better solution.
so here's what i think i need:
XT60 male to deans female (to use that deans connector battery i got from the lazer toys combo)
XT60 male to 4x pigtail (so i can omit the distribution board and not subject it to my atrocious soldering "skills")
more batteries with XT60 connectors
a battery charger
lipo bag(s)
aside from that i'm not sure what else i need. i still have reservations on the mockup of the pixhawk, some of the connections don't seem to make a lot of sense but i guess i just need to do more research. it's also been recommended to me that i pickup some more blades, not only replacement blades of the same kind, but different types of blades to test it with different setups. i'm lost there, because all of this is new to me and frankly there are some ultra noob questions that i'm almost affraid to ask.
what the hell here goes...
what gives with the extra rings that came with the blades? it seems as if the blades mount up perfectly without any adapters or spacers, so i'm not sure what i'm messing up there.
also, is there any easy solutions for mounting the FT camera tray to the knuckles... has anyone done this? i purchased the knuckles and the camera tray thinking they would be designed to work in unison with each other... but they do not. anyone got vid or pics of installing the FT camera mount (the one with the metal hoops) onto a knuckles build?
anything else i should be aware of?
how am i doing so far?
any input will be very helpful so thank you in advance for any replies.
Props: 8x4.5 Emax
FC: Pixhawk +GPS
a battery charger
lipo bag(s)
