tollesding
Hello everyone,
Today I want to tell you on how I built the experimental EDF Jet from Project Air.
I got really carried away by this airplane. I wanted to built something with an Edf so I decided to do it.
At the beginning I printed out the plans for wing, elevator (modified a bit) and rudder ( also a bit modified) from flite test‘s Mic 3. Draw it onto foamboard, cut it out and hotglued it together. (I used the recommended wooden spar). Then it was time to design the fuselage. This took some time as I wanted to get the specific design James‘ had. At the end of the day I had a nice fuselage which I was happy with.
So the basic things are finished. Lets crack on with the electronics. I used a 64 mm instead of an 70mm edf. More details further down. I desigend mounts and 3d printed them out. ( STL files on request). The width of the controllrods are 1,5 mm.
Now some numbers:
Wingspan: 105cm
Length: 88cm (Fuselage: 78cm)
Weight: 620g without battery
Elevator: shortend to 34,5 cm
Height: 21,5cm
EDF: (FMS) 64mm; 3150 kV; 1150g thrust; 11 blades
ESC: 60A Yuki model; only got it working with 5V regulator
Reciever: 4x 9g
Battery: 4s 14,8V 2400mAh
Feel free to ask what you want to know.
Hope you guys enjoyed it
See you
Daniel from Munich
Now some numbers:
Wingspan: 105cm
Height: 21,5cm
Reciever: 4x 9g
See you
Daniel from Munich
