OK, so after this tricopter crash I have to get a new motor for it, so I'm going to play around with the remains of the first one, to see if I can learn something new, and maybe even fix it in the process.
After some research I found that the optimum configuration to wind it would be something called Delta winding, specifically dLRK. This should be done like this:
The number of turns in the pic is just for representation issues, I'm going to use 8x34 stranded wire (should be like the stock config) making 18 turns in the configuration above. Looks like I start from the center and wind to the sides.
I won't start right now, but I wanted to share this to see if I could get some input from experienced guys.
