Hi, I built my first foam board plane, the Old Foggy. I ordered a Suppo 2208/17 combo kit with esc, props and servos from my local hobby shop. When mounting the prop, the prop adapter shaft is too short to allow the prop nut to screw onto the shaft. Is this a common problem, do I have to shave the prop hub down to expose more shaft, or can you get longer prop adapters? Thanks!
