Prop remer
Which prop remer is used for the T ember prop shaft metric or standard ? What is the prop hole size ? Looks close to a 7mm to me .Bought a APC 12X6E PROP and hole is to small for prop adapter.
DamoRC
Scratch that last question, the prop adapter is the same part for both the 1.5 and 1.2m versions. You need an 8mm hole to fit a prop on to that adapter. The prop should have come with adapter rings, one of which should fit snugly onto your prop adapter. Then you can either ream the prop at 8mm (5/16 is close) or a tad larger if you use the adapter ring.
#4
Yes
Yes the prop came with the adapter rings I have the old tember thanks for the help !!!
