Propeller Breaking Mid-Flight?
mmmries
Hi All 👋
I've been getting back into RC flight after years away from the hobby. It's been especially fun to do it with my oldest son who is learning to fly with a buddy box system. Recently we built a Piper Pawnee PA 36 from Tony 65x55's plans from the old rcgroups forum. It flies great with the Emax motor from Flite Test's power pack C. In the last 2 weeks though, I've had 3 propellers split in half during flight. I'll be several minutes into a flight when suddenly I lose power and bring it in dead-stick only to find that my prop nut is still in-place and no propeller to be seen. Today it happened during a low-pass so I was able to find half the propeller and confirm that it is breaking at the hub.
Has anyone else seen this happen? Am I putting it on the motor too tight? Too loose? Any suggestions?
Note: the image below is before I switched out the motor to use an Emax Mt2213-935kv with a 10x45 propeller
Hai-Lee
Old and Bold RC PILOT
I have thrown a few props in flight and normally they are the cheap plastic props and simply put they cannot handle the power and kV of the motors I was using. When I bought some of the more expensive types of props, (GRP or CF), the breakages ceased,
Just my experience!
Have fun!
FDS
I don’t like the waisted root design of those props, an APC style one in the same spec will be better. Look how little material there is round the prop shaft of the motor.
quorneng
With that motor a 10 x 4.5 prop is recommended for a quad. It is intended to generate high thrust as low air speed.
In a plane at speed I wonder is the prop blade is actually 'fluttering' hence the repeated failures. A 9x6 might be a better choice.
mmmries
Thanks for the replies. I have been using really basic ABS plastic props and had not thought about the low pitch of that 10" prop. I'll try out both a higher quality 10x4.5 and a basic 9x6 to see how those both do.
Bricks
Dumb question are you using the plastic insert, that fits the shaft size of the motor? I see you are using a ruber band to hold the prop on is it tight enough to keep the prop from fluttering?
  • Like
Reactions: FDS
Site Moderator
I think you need a proper prop collet similar to this one
  • Like
Reactions: FDS
mmmries
That picture with the rubber-band "prop saver" is from before I switched to the new motor. The Emax motor I'm using now has a threaded prop shaft with two straight edges that catch in the hub of the prop. Thanks for the response!
Brett_N
you are over-tightening the prop nut. This causes a split in the hub, then any slight imbalance causes it to self destruct.
  • Like
Reactions: FDS
Bricks
Are you using the platic inserts that center the prop on the shaft?
mmmries
Interestingly before new props arrived I tried another one of the cheapo ABS plastic propellers and it worked fine. I have now flown with it more than a dozen times and over an hour of flight time. I'll still replace it with a nicer prop the next time this one breaks, but for now it seems to be working fine.
