Psyborgs DGA-6 Mulligan group build thread.
kilroy07
You must feel awesome right now. I actually love those moments when I take a snafu and work it out. Well done.
Peter
Uh huh! Now hopefully when I hit the throttle the first time (or anytime for that matter) the motor pod doesn't launch across the field in a cloud of shredded faux motor foam :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:[/QUOTE]
Well, hopefully that will be after you get some time on the TTs. ;)
PsyBorg
Wake up! Time to fly!
Well, hopefully that will be after you get some time on the TTs. ;)[/QUOTE]
You said we have a time limit for build to maiden. How many planes you want me to be building at once haha.
PsyBorg
Well got the tail surfaces mounted and primed this morning before the wind went all wild for the rest of the afternoon. Will have pics on that in a bit as I have started the finish paint process. After seeing @Mayans last post about gear and the tail cover I saw he had used a BBQ skewer for the tail. I'm not a big fan of that method as I had the few attempts to fly that used it basically grind it off in only a few takes offs. I made a rudder mounted tail wheel for the edge I built a while back out of wire and round servo control horns. Figured since this is a fancy plane it is worthy of an upgrade so I worked out a swivel tail wheel that would not need to be tied to the rudder nor use an added servo.
It is built from 2.4mm stainless welding rod (SUPER hard to bend) two 20mm x 20mm balsa ply and 4 foam squares glued together. I soaked the Balsa in thin CA to keep it from splitting or wearing too fast. Then I took small clear plastic circles cut from the remains of the windscreen mod and hot glued them to the shaft to act as a "bearing" to make it slide better. I will figure where that goes into the plane once I get around to measuring and cutting the hole. The top plastic circle will get glued in place right before it all gets mounted so I don't have to fuss with a floppy wheel in my way when measuring and such.
You can also add a bead of hot glue around the servo horns to make a tire so they don't wear out. I am going to try something more fancy and use flex seal to make the tire.
PsyBorg
You've got an assortment of wheels coming in the mail, should show up any day now... ;)
Guess I better go check the mail then huh. Wont be hard to change things around. I haven't made any changes yet. STILL trying to get the paint mix I want right. First it was too brown, then too green... Kinda hard being accurate with a squeeze bottle of paint. I WILL get it though even if I have to spend another $9.85 on Walmart 12 color paint set.
But the repurposing of unused servo horns is a good idea though right? It turns and swivels so good right now.
Baron VonHelton
I use Mission Models Paint. I use them because they have nearly every military color you can think of, and they are on Ebay.
:D:D:D:D:D:D:D:D
mayan
It’s an amazing idea of what I can do with a dozen or so that I have laying around
PsyBorg
Yea... I'd hold off on that too.... :cool:
Yes I see that. I have box in hand. Interesting to see Testors in that kind of pack. Its also interesting to see the paints are made by Rust Oleum. I almost thought the Walmart paints I got to try were the same as the bottles and packaging is nearly identical. Nothing on the box to say who actually manufactures their paints though.
I love and have always used Testors paints on any model building I did in the past so I will be needing to learn your source for thm sometime in the distant future with all that paint.
Again thank you so much for all the cool stuff you have provided. Its almost time to do another round of the under color base before the cream goes on.
:D:D:D:D:D:D:D:D
I'm new to airbrushing so I am learning on a cheapo airbrush kit and trying various paints. Its amazing the differences in how they mix and thin out. I have though figured out the trigger tension I like as well as how and when to change air pressure to make the paint do what I want.
PsyBorg
So. 5am came and along with it back spasms making sleep impossible. So i got up fired up the coffee pot and the glue gun in that order. I worked a little on the landing gear yesterday getting the front mount completed with the welding wire glued in and shaped. I was going to leave it at that for now until @mayan had shown us what he did but being up so early I got motivated fast. Figured running the tiny air compressor to paint would not be nice to the neighbors as it would surely arouse their barking rats and have everyone up.
I took a look at the wheels @kilroy07 sent and started with the pants. I shaped them and put them together in my hand and thought they looked way too wide for the wheels as well as scale for the fuselage when compared to real life pictures. so I thinned them down by cutting the top plate by 5mm on the front and 3 mm in the rear along the length not on the ends. Temp put the pieces together and that looked a bit better. Once they were glued I did the inner edges using the bead of glue and squeegeed it all out. I wanted to spread it as thin for weight but also to seal as much of the inside against wet grass and general damp flying conditions here. Finally I beveled the edges to give them a less square look and white gorilla wood glued all the exposed edges and foam in prep for priming later today.
Once that was done and my first cup of coffee finished I had plenty of energy and motivation to continue. The next step was to make the back side mount and I had just enough of that piece of welding wire to use instead of BBQ skewer. There was a ton of bending and test fitting to get everything aligned and I forgot to grab the in between shots of the making of the fairings and gluing that all together. This is what that ended up looking like.
Finally it was time to see what it looked like all together. I still have not glued the pants to the fairings yet as the wheels have to be installed before that can be glued together. I'm still on the fence about adding in bushings to keep the wheels centered so they don't bind or over time rub thru. At least I think I have them reasonably even so the full aircraft doesn't have a Detroit lean on the runway.:ROFLMAO::ROFLMAO:
Also you can see the greenish base coat I was talking about earlier.
kilroy07
So. 5am came and along with it back spasms making sleep impossible. So i got up fired up the coffee pot and the glue gun in that order. <Snip>
That's coming along GREAT!!
I've been "Running errands" on the motorcycle the last few nights (iow, looking for any excuse to ride):LOL:
It's bad when two of your favorite hobbies both compete for nice weather!
But rain is in the forecast for today (and much cooler temps after) so I need to camp out at my workbench tonight and catch up!
@mayan we should have one more coming online soon (Not to put @The Hangar on the spot :sneaky:) but the package is held up, so it won't be until the end of the week at the earliest.
PsyBorg
Haven't seen anything from @FoamyDM I figured he would be done built and flown by now. He is a building machine. these kits you cut go together so well. Maybe look into shaving down the wheel pants width in the cut files after you check it out.
PsyBorg
:ROFLMAO: Yea, I thought about that right after I hit the post button... If there's ANYONE I should be calling out it's him! :p
<Edit> Maybe he's still out in the bean field... :cry:
gonna prime the new stuff after lunch and then maybe start the wings after that. I might call you then if you will be available for some questions.
kilroy07
Sure, maybe around 3pm (CST) I've got some virtual meetings right after lunch... From what I've learned, get all your servos ready to go.
(I almost wish I had sent everyone a version without the flaps as well... maybe next time.)
I have my wing built, I just need to iron the edges.
PsyBorg
I fly with flaps in my sim all the time. I like the fact they are there. this will be my first real plane that has them. So like after 5pm my time Ok if I am not napping by then after being up so darn early.
That's probably NOT a bean field.
