PsyBorg
Wake up! Time to fly!
Ok I got my stuffs from Rotor Riot store that I needed to put together one of their sweet Kiss based 5 inchers. I know there are cheaper ways to get some of the parts but they come on a row boat from China mostly. Besides I try to support people who have helped my or entertained me in some way. Rotor Riot got me my stuff yesterday after only ordering it Monday in the middle of the night. Came in a hefty box and was packed well so everything was in perfect condition. Kinda bummed there was no skull sticker to plaster on it. I was going to get a shirt and a sticker pack but last minute decided to go with the 2250kv Lumineer motors instead of the Emax red bottoms.
Got the parts unpacked and laid out nicely after pulling up FGA's build video to guide me for the most part. Already had it memorized practically but hey always good to make sure huh. Anyway started with the first part of filing all the sharp edges off. Did it in a tupper ware container of water so I wasn't leaning over a sink and wreckin my back before I even got started. Nasty Nasty stuff that is.
Next was to tin the PDB and add the XT60 connection. I may change that as the leads on my graphene batteries are short and I don't want to stress them. Time will tell once I am into the tuning phase whether I will live with that or change it. Anyway got that all tinned and cleaned so it was time to build the lower frame.
Next was mounting the camera to the tilt mount. If anyone uses these leave the adjustment screws just a hair loose and you won't have to fight to line up that frame in those tiny slots. I didn't file the edges on the mount as it is hidden but the standoffs so minimal chances to cut yourself and or wires.
After that it was time to prep all the wires by cutting them to starting lengths and tinning one end of each. Also the esc's were pre tinned and cleaned to get ready for assembly. Make sure you clean the flux off any pcb as it is not only a dirt magnet it is also very corrosive to electronics. It is a mild acid after all. I use alcohol and an old tooth brush and then wipe it dry before soldering the wires then clean it all again to make it shiny and neat. The Kiss esc's are very well thought out I specially liked how you can solder all four motors the same way to keep consistent and neat and only have to close a jumper to reverse two of the motors right on the esc. The only thing I did not like was that the ground pad for the link between FC and ESC is kind of small and if you don't have a good ground you will have all kinds of issues.
Next was time to mount all those to the frame. Unfortunately I had to use some of my own heat shrink for the esc's and not the clear one they provided. The stuff that came with my kit was like double the size in the build and so thick I could not get it to shrink enough even when wrapping the arms and the esc's together. Hopefully I wont have to troubleshoot the esc's as I cant see the blinky lights on them. The foam pad and the electrical tape is a nice quick and easy way to mount them securely and is easily redone when its to covered in grass and dead bugs to be presentable.
A quick way to make the wires neat is to use a screwdriver shaft to form the motor wires the same way. Just put it under the wires lift up a little as you move the esc closer to the motor until you have it centered on the boom where you wish to mount it and it now looks nice and even and neat.
At this point I attached the foam landing skids as it makes it easier to work on by keeping the frame from sliding on the work surface. It also protects the anodized screws on the bottom.
This post is getting long so Ill start a new one to finish showing the build.
