Wow did you clear coat that too? or just buff n wax it? It looks much shinier in your pictures.
It's all in the lighting
Once that has been tested and maidened a cockpit would complete it. I started to design it and I think I left you the pattern and the blueberry package lid to cut it from didn't I? No biggie without it as long as it flys for you I will be very happy and glad you took time to finish it up.
I think you did send me home with the pattern, but I've lost it in the chaos of the workshop and will probably find it again packing for FliteFest next summer
I was thinking of doing some sort of quick air diverter thing to reduce the drag for maiden flight, and then once I know she's going to stay in the air for a bit take the time to build up a good one.
Did you go with my idea to line the aileron cutouts in balsa or did you do something different?
I'm embarrassed to say I cheaped out again here in the desire to get in the air and left it with foam lining rather than balsa. The balsa would be more secure and last longer - and again I hope to come back to that after a couple flights.
Oh yeah forgot to answer you about original prop for that motor when it was on the Pitts.. manual says 13x6 and I sent all the ones I had with you for that. The speed controller is a 50 amp in case you cant dig in and see in case you want to run numbers for different props. The motor is BM3720A-KV650 and I believe they are both made by Detrum
Thanks! I'll dig through the prop pile for that one, or something close
