Push/pull twin motor versa wing
Hutch Bunch Rc
This is just tapped on my edf versa wing, so imagine there being no edf
Thought?
Hutch Bunch Rc
Huh, that's pretty clever. I wonder if it goes any faster in-line compared to side by side mounted.
Thanks, I think the inline may possibly be faster than the normal configuration, I build one
but I think the inline would have a little bit less drag, so probably a little faster, maybe a advantage with thrust or something but I’m not that smart 🤣
Hutch Bunch Rc
Decided to finally start on the push pull versa wing, this is about 2 hours of work, the longest part is printing, taping and cutting out the paper plans, let alone cutting out the foam. I still need to hook up the elevons, put on winglets, and make the nacelle which is a modified power pod to have a firewall in the rear.
Hutch Bunch Rc
I want to know it anyone else would want to build one of these, I just used x2 of the $6 value hobby 2200kv motors with cheap 30a escs. And two 1300 3s 30c batteries. All very cheap things and it flys good and sounds even cooler.
In the end the wing weighs the same as a normal versa wing with a 2200 3s. So as you can imagine with twice the thrust the push pull versa is pretty quick. Let me know if you decide to build one! I think it would be awesome.
Hutch Bunch Rc
Video?
Could you make some comments if it is better/worse than single engine in areas of yaw, pitch?
I’ll get a video new time I go fly, As to how it flies? Exactly the same as a one motor/ normal pusher versa wing. Same yaw and pitch control and feel. It’s just about twice as fast.
