In your last episode you mentioned part of the reason EDFs are so inneficient att low speeds are the angle of attack of the blades. Can you try and put a Swash plate on an EDF, Like on the FT Viggen for example, hook it up to an air speed-meter, and control the angle of attack of the blades based on air speed? I realize you might need to make custom blades or modify the ones of some prop, but wouldn't it be awesome if it works?
Also, why didn't you use an FT foamboard plane to modify into your 3d-plane?
