Q450 v3 - Power distribution board - short circuit after soldering ESC or not?
lpinho
Hi all,
just bought a Q450 v3 quad frame.
I solder all ESCs to the Q450 v3 power board.
To check if everything is ok, I used my multimeter in transistor mode and:
- 1st, + with +
Result: Started with a value that reached 0 after a few seconds (common behavior when connectivity exists)
- 2nd, + with -
Expecting: No value
Result: Value on screen will rise until I get a stable 1550
At this time I though I had a short circuit
So, I turned the multimeter to the resistance mode and repeated the tests:
- 1st, + with +, R = 0
- 2nd, + with -, R will increase (didn't wait for the final value)
I had a few extra ESC around and tried to connect the multimeter to their battery terminals and I got similar values (if I connect the multimeter to the battery connector I get value in the transistor mode and in the resistance mode like in the board after soldering the ESCs).
Does this mean that this is the normal behavior? Or I have a short circuit?
BTW: I run the tests before soldering the ESC and the transistor test returned a negative conductivity
Thanks for all your help,
Luis Pinho
lpinho
Could you guys just make a small test with your multi copter and check if this is a normal behavior?
Craftydan
Hostage Taker of Quads
You've got the ESCs wired in, right?
The ESCs have a fairly large capacitor in each for filtering -- all in parallel so that makes a VERY large capacitor bank. The instant your multimeter applies a current across the voltage rails (which it does for either continuity or resistance measurements), that capacitor bank will look like a short as they sink as much current as your multimeter will source.
After a few seconds to charge up the caps, you're down to the internal input resistance of the ESCs themselves. That shouldn't be infinite but I'd expect it to be in the k-ohm region while the voltage/current is too low to boot.
jipp
woohoo. congrats. itsa great feeling once it takes off for the first time.
well heck, i get that feeling every time it goes up in the air. im hooked.
chris.
