You need to know that that is with 95% certainty _not_ a qav250 frame. Most likely a knock off, built cheaper with carbon/glass mix instead of pure carbon. That said, it's not a bad deal, the motors, esc's and FC should be fine, and to get everything in one place is nice.
I do worry about getting replacement arms though, are they available? Banggood aren't exactly fast with regards to shipping, so if you end up waiting for arms that can be a pain. For that reason I might consider getting zmr250 frame instead, they are so common now, that arms can be found everywhere. This looks like a proprietary design (real qav250's don't have replaceable arms, they are part of the fram), so finding arms can be a pain, and they tend to break if they are not real carbon fiber.
I have heard good things about these frames, which are based on the zmr250:
http://multirotormania.com/frames/94-100-carbon-fiber-250mm-mini-frame-version-i.html
The only thing is that the battery and charger are not the best. The 2200 battery is kind of heavy for a 250, a 1300-1500 is better. The charger probably works, but you will want to get a better charger shortly, as well as more batteries.
The kit includes a deans connector, I would get XT60's instead.
