Hello. I am a bit new at this, and Im having a bit of an issue:
trying to run fpv gear on my quad everything seems fine till I get just a little ways away maybe 100ft, probably less, when I lose all control and my quadcopter falls from the sky till it regains signal. ive only flown it 4-5 times with the fpv setup on it (mainly because last time it didnt regain signal till it was 5ft off the ground and burred itself in the dirt). what am i doing wrong here my setup:
x666 frame
kk2.1 board
turnigy 30amp escs
zippy compact 4000mah 25c lipo
1000kv motors
hobbyking hk-t4a v2 tx and rx
and for the fpv:
900mhz system
cloverleaf antennas
standard board camera
running off of its own 1000amp lipo
i did mount the fpv setup fairly close to my rx on my frame (less then 4inches away) but I didnt think they would effect each other since one is 900mhz and the other is 2.4ghz. I did get a turnigy 9x tx and rx just havent flown it since (raining for the last three days)
please help!!
x666 frame
kk2.1 board
turnigy 30amp escs
1000kv motors
and for the fpv:
900mhz system
cloverleaf antennas
please help!!
